With a stated 57,000 miles (and original tired), just freshened barn find, could this car make a 4 Star candidate?
57 Aztec barn find on ebay
Re: 57 Aztec barn find on ebay
Here's the link. http://cgi.ebay.com/ebaymotors/Chevr...item27c18b6948
I don't know much about that generation, but it sure looks neat.Tom Hendricks
Proud Member NCRS #23758
NCM Founding Member # 1143
Specialist for 27 years at BUDS Chevrolet.- Top
- Top
Such small, low resolutions photographs for a car like that. The person running the auction really isn't doing it justice if in fact it's as original as they suggest.Vice-Chairman (West), Michigan Chapter NCRS
Original tires - highly unlikely for 50k miles, 10-15k miles if lucky
Tachometer rev counter 450,250 revs?
Gary
NCRS Texas Chapter
https://www.ncrstexas.org/
https://www.facebook.com/profile.php?id=61565408483631- Top
If you assume a 3.70:1 rear end and tires that make about 750 revolutions per mile, then the actual vehicle miles needed to total that many thousands of revs would be about 162,000.
So, 57000 miles? Definitely not.
Jim- Top
I guess I was not clear as I am aware of the function of the Tachometer. I am not sure what the reading of the counter would have to do with the revolutions of the tires and gear ratio etc. I know the faster the speed the more RPMs. How can mileage and engine RPMs coounter compare, Next to impossible I would think the car surely is not in constant motion. Am I missing something here.- Top
A mile is a mile, whether you're going 100 mph or 10 mph, so the number of revolutions of the tires and engine is the same. Obviously, the car would also do some idling, so you can't hit the number of miles exactly, but that many RPM's has to be a whole lot of miles or an unbelievable amount of idling.
The counter built into early tachometers indicates the cumulative number of engine revolutions, measured by thousands. In the case of the '57, the rev counter (or totalizer, if you prefer) indicates the engine has turned approximately 450,250,000 revolutions.I am not sure what the reading of the counter would have to do with the revolutions of the tires and gear ratio etc. I know the faster the speed the more RPMs. How can mileage and engine RPMs coounter compare, Next to impossible I would think the car surely is not in constant motion. Am I missing something here.
If the car has a 3.70:1 rear axle ratio, and if every engine revolution resulted in wheel revolution, then the wheels would have rotated approximately 450250000/3.70 = 121689189 times.
The tires on that car would rotate approximately 750 times per mile. So the approximate mileage suggested by the rev counter can be calculated as 121689189/750 = 162252 miles.
Your observation that the car is not in constant motion is valid. What that means is that the actual cumulative miles will be somewhat less than 162K.... hmmmm... maybe 157K, which would be consistent with the odometer reading.
My unrestored '54 has 79,000 miles on it. The rev counter reads 220748(000) which, using my method above, suggests 82000 cumulative miles.... clearly but not substantially more than the actual miles. The "missing" 3K miles is due to engine idling.
Jim- Top
or....the trans was stuck in 1st the whole timeMike
1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.- Top
