66 390 hp cam - NCRS Discussion Boards
66 390 hp cam
  • Anthony P.
    • October 26, 2011
    • 199
    66 390 hp cam
    Can anyone tell me of any identifying marks to determine an original 66 390HP camshaft? I have a cam with the groove and no part # on the rear of the rear journal at 12:00 is an A and at 6:00 is a J and at 3:00 is what appeers to be an underscored A with something next to it? Looking for some guidance.
    Thanks in advance
    Re: 66 390 hp cam
    Thanks in advance
    Anthony -
    That cam core was casting #3883934; I'd look for "3944" cast into it somewhere between the lobes.
    • Anthony P.
      • October 26, 2011
      • 199
      Re: 66 390 hp cam
      John Thanks I just checked and found the numbers!! it is the original cam that I took out 35 years ago when I was 20 years old, and installed a solid lifter 173 cam. I had the sence back then to oil and grease it and wrap it. but didn't think to LABEL IT just a dumb kid. I set it up on V blocks and checked the lift with a dial indicator, seems that all the lobes are down.010-.015 from the spec of .2824 and .2714. Wan't to make it "as original" as that is the only alteration that was made since I owned it.
      Thanks again you guys have all the answers!!
        • 15706
        Re: 66 390 hp cam
        ...never heard of a "173 cam".
        • Anthony P.
          • October 26, 2011
          • 199
          Re: 66 390 hp cam
          Duke you are correct error on my part wanted to type in 143 good catch!! it was 10:30 last night lucky my brain worked at all!!!
          Thanks Tony
