63 Brake booster push rod - NCRS Discussion Boards
    • 6950
    Does any one have the push rod length on the brake booster to master cylinder and inside pedal length?
    having problem getting the air out of system doesn't seem to be pushing fluid to bleeders. I am converting to power brakes with the correct 63 master and booster.
    Thanks for any help Ed
  • John N.
    • November 17, 2009
    • 4
    Re: 63 Brake booster push rod
    Edward
    I measured my 63 booster from the mounting flange to the tip of the rod is 1.2 inches and the center of mounting firewall flange to center of clevis hole is 3.9 inches. As both are adjustable I don't know what the factory set it at. I hope this is what you needed.
    John
      • 6950
      John, thanks for those measurements that is exactly what I need.Is your booster in the car?
      • John N.
        • November 17, 2009
        • 4
        Edward
        the booster is currently out of the car due to a vacuume leak, I installed a aftermarket booster with dual master and 4 wheel disk brakes for safety reasons since I try to drive it as much as possible in the summer months
        John
