63 Conv. Windsheild Install - NCRS Discussion Boards
    • 6961
    What is the correct way to install a windsheild in my 63, use the rope method, or use a plastic spoon around the rubber gasket to install? maybe someone has seen this done or has installed there own.
  • Paul Y.
    • September 30, 1982
    • 570
    Re: 63 Conv. Windsheild Install
    I used the rope method on a coupe.
    It's a good life!
    • Michael G.
      • January 1, 1997
      • 1251
      Ed,
      Suppose it could be done however have not heard of the spoon method. Seems labor intensive but the way to go is the rope method and a helper placing pressure on the glass.
        • 6961
        Originally posted by Michael Gill (28614)
        Ed,
        Mike,Paul Thanks for the response could one of you tell me where you start the rope and end it, I am thinking starting at the bottom and ending at the bottom,is this correct?
        I have a windsheild try to install the windsheild with plastic type spoon from the outside but the weatherstrip did not seat correctly on the bottom so we removed and was going to try the rope method next week.
        • Wayne W.
          • April 30, 1982
          • 3605
          Overlap at the bottom. Work out from there.
          • Paul J.
            • September 9, 2008
            • 2091
            Ed, I have used the rope method, starting at the bottom and working my way up both sides at the same time in order to maintain even pressure across the windshield.
            Paul
            • Claus S.
              • December 30, 2010
              • 414
              Have a friend push the windshield from the outside when installing
              If you have a new weatherstrip seal and they are usually very hard you can put it in how water and it will be much more easy to work with
              • Michael G.
                • January 1, 1997
                • 1251
                Ed,
                As others have stated starting at the bottom is best. Be sure when inserting the rope into weatherstrip you cross the rope ends over each other, then start pulling from bottom. Top corners are typically the most difficult....go slow and be patient, you don't want to tear the w/s. Your assistant will need to put pressure on wind shield from exterior. I choose to place the windshield sealant into channel (along w/rope) before the install (messy but doable). It can be done afterward....this is just how I do it.
                  Edward -
                  That's how the plant did it - started at the bottom, ended up at the top center.
                  • Wayne W.
                    • April 30, 1982
                    • 3605
                    Edward -
                    Workers dressed well at the plant.
                      • 6961
                      Guys, Thanks for all the great tips and pic.s. Ed
                      • Jack P.
                        • March 19, 2009
                        • 1135
                        Hi Ed, here is the post on my windshield install last month on my 66
                        He used the rope and it took just a few mins. Lots of pictures in post
                        Jack
                        https://www.forums.ncrs.org/showthread.php?t=89275
                        • Claus S.
                          • December 30, 2010
                          • 414
                          Nice rust free window frame Jack
