Feb. 64 voltage regulator mounting holes - NCRS Discussion Boards
  • Jaime M.
    • January 1, 2005
    • 32
    Hi Everyone,
    When did they change the mounting location for the voltage regulator in 64 with no A/C from the radiator support to the fender skirt? My car was a February 64 built car and there are no holes in the fender skirt. I was getting a bit confused when I wanted to order mounting hardware for the regulator and the suppliers are selling fender skirt mounting hardware for the 64, The Judging Guide states Rad. support mount. Does anyone have any info on the correct location of the holes on the support for the volt. regulator and the horn relay? My support seems to have extra holes that someone may have made in the past.
  • Dan H.
    • July 31, 1977
    • 1372
    Re: Feb. 64 voltage regulator mounting holes
    Jaime, my March 64 Coupe still has the voltage regulator and horn relay on the radiator support, no holes ever in the fender skirt etc. Vin 13708, St Louis built car.
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • Alan D.
      • January 1, 2005
      • 2055
      And here's where another March 1964 was mounted. Know that page of the AIM always bother me too! However note it has a date of 4/8/64 when it got revised. So you will need to look at the 63AIM for the placement.
      • James W.
        • December 1, 1990
        • 2680
        Jaime,
        My January 18, 1964 built Corvette with a 327/300 and non a/c has the voltage regulator and horn relay mounted in the same locations on the radiator support as Alan's.
        James West
        • Doug L.
          • March 14, 2010
          • 442
          Ditto my December 13, 1963 car. I beieve there is 1 extra hole in the radiator support, oval in shape, approximately 1" x 3/4", with flaired circumference toward the engine compartment, like it was pressed through the sheet metal rather than drilled. Other than that hole there are three mounting holes for the voltage regulator and horn relay.
          Doug
