C1 (1960) door glass tape - has someone does theirs recently? - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2580
    I have new glass for my door windows and have two different type of tape.
    One set from Corvette Central looks like it has some sort of fabric on one side and neoprene on the other side with seems to be some adhesive on the neoprene side. It actually looks more like what was on the old glass, but the old glass was not original, it had a 68 date on the glass.
    The other glass tape is from ZIP and it looks to be solid neoprene.
    The other difference is there is a slight difference in thickness, the CC tape is .068 and the ZIP is .063
    Which one is correct, or if it doesn't matter, which one will be easier to work with.
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • John T.
    NCRS Financial Officer
    • January 1, 1983
    • 292
    Re: C1 (1960) door glass tape - has someone does theirs recently?
    The tape is used on my 62 was the solid neoprene. I would think the adhesive would make it harder to install and certainly is not needed.
    Good luck
    John
    • Donald H.
      • November 2, 2009
      • 2580
      Good luck
      John
      There isn't much adhesive on the tape. I thought it might be easier to use if I could get it to sort of stick to the glass then lubricate the outer with soapy water to get it to slide into the frame. I have soft faced large wood clamps to help force the glass into the frame.
      Don
      Don Harris
