64 Wheels - NCRS Discussion Boards
64 Wheels
  • Ken J.
    • May 11, 2008
    • 95
    64 Wheels
    Hello;
    I have some 64 wheels with no date stamps inside the rims. They have the GM on the ribs by the lug hole. What can you guys tell me about them?
    Ken Joseph
    Re: 64 Wheels
    Originally posted by Ken Joseph (49012)
    Hello;
    Ken Joseph
    Ken -
    Not much without some pictures.
    • David L.
      • July 31, 1980
      • 3310
      Re: 64 Wheels
      Having "GM" stamped on them does not tell me anything other then they are GM wheels. Are they stamped "15 X 5 1/2 K", "KELSEY HAYES", and have the Kelsey Hayes logo on the inside? Is the offset 7/16"? Are they welded or do they have rivets?
      Dave
      • Ken J.
        • May 11, 2008
        • 95
        Re: 64 Wheels
        Hello;
        The wheels are welded. I didn't see any K/H. How do you measure the
        offset? Pictures coming Monday.
        Ken Joseph
        • David L.
          • July 31, 1980
          • 3310
          Re: 64 Wheels
          The offset distance from the mounting surface to the center of the wheel.
          • Alan D.
            • January 1, 2005
            • 2046
            Re: 64 Wheels
            Here is an original Mar64, inside rim with date, notice the "1" by the 15 and then the "64" by the 1/2
            (notice the slight yellow primer showing, I have also noticed the same yellow stuff on my left trailing arm just a little. Not typical however stock stuff for that day and still a mystery)
            • Doug L.
              • March 14, 2010
              • 442
              Re: 64 Wheels
              Looking at the profile would tell you a lot. '63 / '64 wheels have a tapered center hub.
              • Ken J.
                • May 11, 2008
                • 95
                Re: 64 Wheels
                The profile is good. The offset is 7/16, but no stamps but the GM on the
                face of the wheel. What do we have here?
                Thanks to all.
                Ken Joseph
                • David L.
                  • July 31, 1980
                  • 3310
                  Re: 64 Wheels
                  Thanks to all.
                  Ken Joseph
                  I assume the wheel is stamped "15 X 5 1/2 K" or at least measures !5" and 5 1/2".
                  Does the hub hole measure 2 25/32" in dia. or 2 29/32" in dia.?
                  Is there a small hole (about 1/8" dia.) in one of the 5 "bumps" on the front face?
                  Are there any stampings near the valve hole? I believe that the stampings near the valve hole on the K-H wheels began sometime in 1967 or 1968. I would have to check my research to be sure.
                  Dave
                  • Alan D.
                    • January 1, 2005
                    • 2046
                    Re: 64 Wheels
                    And the face shot;
                    Note no hole, no stamp @ valve stem Again comments based upon a Mar64 rim after that no comments.
