Temp Guage Rebuild Recommendation - NCRS Discussion Boards
  • John L.
    • February 1, 2005
    • 207
    I am preparing to send out for rebuild my temp guage on my 54 and wanted to get some "up to date" recommendations from fellow forum members on who they have had good experience with recently.
    the car was not running when I purchased it so I have no idea if the unit was working properly or not.
    Would appreciate any solid leads.
    John Lanning
  • Chris S.
    • January 1, 2000
    • 1068
    Re: Temp Guage Rebuild Recommendation
    I sent mine to Corvette Specialities
    Make sure yours has the correct square nut on the temp probe or you can supply the correct one to them to install.
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • John L.
      • February 1, 2005
      • 207
      Sorry but would that be Corvette Specialties in MN???
      • Mike M.
        • May 31, 1974
        • 8409
        before sending it to brian tillis at corv specialties of maryland(they moved to so cal recently but are still online) , i'd boil a pan of water then imerse the sending unit end of the temp assembly into the bouiling water. if the capillary tube is intact, i'd bet the gauge will work. if not, send it to brian. good luck,mike
        • Chris S.
          • January 1, 2000
          • 1068
          sorry - of MD
          but they moved to Calif
