I planned to re-use my original speedo cable when I reassembled the car but broke it when the body went back on the frame. I removed the end of the old cable from the speedometer and attached the new cable. I fed the transmission-end through the firewall and through the transmission tunnel then jacked up the car and slid underneath. I can barely see the connection point on the side of the transmission and see no way to get my hand in that area without at least removing the front exhaust pipe (which also probably means at least removing the rear pipe and muffler too). Does anyone have any suggestions about how to connect the speedometer cable to the transmission without disasssembling things? I'd like to know how others have gone about making this connection before I start tearing things apart.
Thanks in advance for any advice.
Doug
Doug
