Re Heater defrost question - NCRS Discussion Boards
  • Wayne P.
    • January 23, 2008
    • 444
    I just took out the radio , clock and glove box and noticed a gap between the heater box and the defrost vent . Looks like about 1/2 inch. I was looking in my repair book but didn't see if their was a rubber gasket required or not. The insulation is also in poor repair. . Thanks for any comments.
    • 6956
    Re: Re Heater defrost question
    Wayne I noted the same on my 63 conv. I think they were pretty crude,I Did not see any signs of a seal when I took my interior and heater apart.
    • Harry S.
      • July 31, 2002
      • 5344
      Ever hear the expression, "let your wind blow free". It was kinda that type quality of assembly!
      • Wayne P.
        • January 23, 2008
        • 444
        Maybe wrap it with foil tape ?
          • 6956
          Wayne, if you have a Home depot or Lowes, get yourself some of the foam weatherstrip sealer, It comes in all different sizes and widths.The duct tape may show once together.
          • Wayne P.
            • January 23, 2008
            • 444
            Great thanks
            • Stuart F.
              • August 31, 1996
              • 4676
              I have not looked at mine in a number of years, but are you sure it is not intended to be that way? Perhaps it is meant to mix ambient air with "treated" air, so to speak.
              Stu Fox
              • William C.
                • May 31, 1975
                • 6037
                The gap described is "as intended". Owner inspired modifications are as always at the owners discretion.
                Bill Clupper #618
                • Aaron A.
                  • February 1, 2011
                  • 6
                  The above is exactly what I did.
                  Actually, when comparing the "official seal kit" for my vette I bought, the "regular" weatherstripping sealer worked better.
                  • Wayne P.
                    • January 23, 2008
                    • 444
                    Well I don't think I will require the defroster the next time we get snow and ice pelting down : ) Have a great Christmas season. Wish I were in a warmer climate.
                      It's designed with that air gap between the case and the defroster yoke on purpose, to avoid noise/vibration from the heater case from being transmitted directly to the main dash panel, which would then amplify the sounds. That was standard Chevrolet design practice for many years.
                      • Wayne P.
                        • January 23, 2008
                        • 444
                        Thanks John I will leave it alone.
                        • Tom R.
                          • December 20, 2010
                          • 177
                          In doing so you'll find that with the defroster on you'll still get some cabin heat through the floor and radio side panels.
