69 seat belt grommets - NCRS Discussion Boards
  • Brad S.
    • July 31, 2005
    • 227
    How were the seat belt grommets on the outer seat belt attached to the carpet? Were they glued or sewn in?
    • 43248
    Re: 69 seat belt grommets
    Brad-----
    They were definitely not sewn in and I don't even think they were glued. I think they were designed so that the "flanges" on the grommets would retain them. However, mine were not very well retained from day-one.
    • Chuck G.
      • May 31, 1982
      • 2036
      FWIW, I've seen many grommets with staples and/or staple holes in them, one on top, one on the bottom.
      Chuck
      • Brad S.
        • July 31, 2005
        • 227
        Joe, my originals were badly damaged and not usable. Got some from paragon that are rubber. were they rubber or vinyl? Thanks Brad
          • 43248
          Brad------
          They were some sort of plastic, not rubber. However, they are somewhat pliable so they might be mistaken for rubber
            • 43248
            Chuck
            Chuck-----
            I rechecked mine and there's absolutely no evidence of staples.
            • Brad S.
              • July 31, 2005
              • 227
              Joe, are they interior color?
                • 43248
                Brad-----
                Mine are black. I believe the other interior colors had matching-color grommets.
                • Brad S.
                  • July 31, 2005
                  • 227
                  Thanks Joe
                  • Jim M.
                    • February 23, 2009
                    • 233
                    Mine had two staples each.
                      • 43248
                      Jim------
                      This must have been some sort of "assembly-line-developed interim fix" for the poorly fitting grommets. These things never installed properly and I suppose the assembly line workers had to improvise to do the best they could with them. At the time my car was built (mid-September, 1969) they were not using the staples, at least when my car went down the line.
                      • Mark D.
                        1984-96 Team Leader
                        • June 30, 1988
                        • 2157
                        Jim,
                        When was your car built?
                        Thx,
                        Mark
                        Kramden
