Polishing Plexiglas Rear H/T Window - NCRS Discussion Boards
  • Joe M.
    • April 30, 1990
    • 1342
    What is the best procedure to remove scuffs, minor scratches, and then polish the window?
    I purchased a plastic headlight cover polishing kit because I thought it might be the same process, but want to hear from Vette owners that have done this before.
    • 43257
    Re: Polishing Plexiglas Rear H/T Window
    Joe-----
    The types of plastic are different. I believe most current headlight lenses are some sort of polycarbonate. Plexiglass is a different formulation, so I don't know if the headlight lens polishing kits are appropriate.
    However, the first thing I'd try would be something like Meguiars Plastic Polish or Arrow Magnolia Plastic Polish. Both of these are used to polish plexiglass windshields in light aircraft and work great.
    For something like this (as well as many other restoration situations), always use the least aggressive method first.
    • Stan G.
      • January 1, 1996
      • 106
      Joe , I'll answer this post as well , I used Meguiars PlastX polish I bought at Advance Auto parts . I used it with a buffer and foam pad . If you have any scratches that won't polish out you will have to use 1550-2000 grit sand paper to remove the scratches and then rebuff . Like Joe L said try less agressive first .
      Back in the 60's I got lots of practice buffing out scratches on my first 58 when service stations would use their blue paper towels on the back window if I forgot to tell them not to clean the back glass . Does anyone remember the days of full service gas ? A blue towel must be the equivilant of at least 2000 grit . Stan
      • Joe M.
        • April 30, 1990
        • 1342
        Re: Polishing Plexiglass Rear H/T Window
        Thanks to all for the information. I only have one wide scuff mark and minor scratches, but will probably go over the entire window with 2000 grit wet/dry sandpaper, then buff with plastic polish.
        • Steven B.
          • June 30, 1982
          • 4002
          Yep! I worked at a Mobil station in the '60's and the blue paper towels were rough---and were impregnated with soap.
          Steve
          • Stuart F.
            • August 31, 1996
            • 4676
            I suppose my 63 top with stress cracks in it from improper storage (stood up on end) is a lost cause.
            Stu Fox
            • Joe M.
              • April 30, 1990
              • 1342
              There is no product that I am aware of that will remove the stress cracks as they penetrate the thickness of plexiglass; not a surface feature that can be removed with buffing/polishing.
              • Gerald C.
                • June 30, 1987
                • 1304
                Has anyone used--Novus Fine Scratch Remover-- I bought it years ago from a Harley Davidson dealer and it is supposed to work well on motorcycle helmet from shields. I have some scratches I need to take out of my 1967 rear window.
                • Joe M.
                  • April 30, 1990
                  • 1342
                  Novus will polish very fine, light scuff marks and scratches, but most of them will still be there. Use a buffer on a slow speed. It will shine the plastic.
                  • James G.
                    • May 31, 1976
                    • 1556
                    Yes Stan. I was a SHELL DEALER, 1966-79, then CHEVRON, and UNION 76.
                    I used to polish my Corvette rear plexi with a product my airplane friends gave me. Very similar I am sure to Meguires PlastX polish.
                    • Harry S.
                      • July 31, 2002
                      • 5332
                      Take a peek...
                      https://www.forums.ncrs.org/showthre...=window+polish
                      • Patrick C.
                        • January 16, 2013
                        • 327
                        Another
                        National Corvette Restorers Society Oklahoma Chapter. Corvette enthusiasts from Oklahoma and surrounding states who join together to celebrate and enjoy the Chevrolet Corvette. The Oklahoma NCRS Chapter members hold regular monthly meetings to share our interest in the Corvette. This is a place to find like minded individuals to support your passion, whether you are driving a brand new Corvette, restoring an old Corvette or just trying to relive a past Corvette experience.
