Need advise on 65 Vette Speedo and odometer - NCRS Discussion Boards
  • Walter L.
    • December 4, 2009
    • 1
    My 65 Coupe has 66 327 Corvette engine and 4 speed. Not sure if 4 speed is 65 or 66 but appears original. All the rest of the car appears to be original. The Speedo is about 8-10% generous in reading on a constant basis and when parked is not a zero but about 10mph below zero. Do not know if anyone can understand or help but would really appreciate it. Seems that if needle was on zero the Speedo would be about correct , or at least up to any highway speeds we would use.
    Also Odo I assume is not working as we are not showing any miles increase as we drive. Is this a Speedo problem or a gear problem in the gearbox or any ideas?
    Thanks, any helpful answers would be much appreciated.
  • Terry D.
    • May 31, 1987
    • 2697
    Re: Need advise on 65 Vette Speedo and odometer
    Walter
    Sounds like it's time to pull the speedo and send it out to be recalibrated. As for the odometer, they can fix that at the same time.
    • Carl N.
      • April 30, 1984
      • 592
      Agree with Terry time to recondition speedo. Gearbox should be ok. You may also need to change speedo gear in trans tailshaft to match rear ratio. You can google this info and there have been several how to articles in the "Restorer" over the past years.
      • Dick W.
        • 10483
        There is a frequent poster here, Joe Ray, that does excellent instrument repair.
        Dick Whittington
        • Joe R.
          • July 31, 1976
          • 4552
          He also advertises in the"Driveline" with telephone number so he can be reached anytime.
          The phantom
          • Dick W.
            • 10483
            The phantom
            Ain't never seen ya ad Hog Farmer
            Dick Whittington
