paint chip repair - NCRS Discussion Boards
paint chip repair
  • William F.
    • June 9, 2009
    • 1364
    paint chip repair
    Anyone used the "Langka technology" product sold by various vendors for paint chip repair? It's supposed to smooth the touchup paint "blob" level with the rest of paint by rubbing the supplied liquid on the touch up blob you've built up.I've got a small, about 1/8"by 1/8' chip to repair on a lacquer white '67.
    Bill Ford
  • Anthony S.
    • April 30, 1998
    • 156
    Re: paint chip repair
    Any one have any luck with this product?
    • Bill S.
      • April 30, 2002
      • 154
      Here is an excellent thread on key/paint chip repair.
      Key Repair-Step by Step Procedure I was contacted by a member on L2D for a referral for his sister in law for a scratch repair. The car was a medium gray Corolla and had been keyed heavily down 2 doors. I quoted her a price sight unseen. She called the day before to say it had been hit on...
      Bill Strobel
      Owner Independent Towing
      Fayetteville, NC
      1979 Corvette White/Red L-82 4 spd
      Only 4,200 miles
      Do It Right or Don't Do It At All
      • Roger P.
        • February 25, 2009
        • 354
        Hi Bill and Tony,
        I have used Dr. ColorChip to repair small chips and scrathes on my Rally Red paint. I think the product works very well and it is easy to use. If you don't get the chip filled completely the first time, you can go back and hit it again with a second application. I work it until it is very close to even with the adjacent paint, and then after letting it cure for a couple weeks, finish it off with some light compound and wax. You just have to be patient and take it slow to get it looking decent.
        Good luck,
        Roger
        • Bill H.
          • August 8, 2011
          • 439
          I have the Lankga stuff (used on my Black Rose Metalic 92), it's OK for small chips (like your 1/8th) but I'm not that impressed with it when used on scratches. I would think the DR. ColorChip would be close to the same technology. I'd like to try Dr. first hand but,I went back to doing something close to Bill's link especially using a toothpic instead of a brush. What Roger said about patience, filling it more than once, letting it cure than compounding - yep.
          That small chip in white laquer should be fairly easy to fix.
