HELP*** What Are These Clips *** HELP - NCRS Discussion Boards
  • Monte M.
    • January 1, 1991
    • 687
    I need a little help. Can anybody tell me what these clips are used for? I was told they were for a mid-year car.
    Any input would be appreciated.
    Thank for taking the time.
    M
    • 6940
    Re: HELP*** What Are These Clips *** HELP
    Monte, The one on the right appears to be a tunnel insulation retainer.
    • Monte M.
      • January 1, 1991
      • 687
      Can you tell me exactly how they were used?
      I will take a look in the AIM.
        • 15595
        Those tunnel insulation retainers were used on 1968-1972 (and probably later as well, but I don't know nut'in' 'bout them).
        Aluminum rivets through the two holes to hold them to the fiberglass and then the tunnel insulation was pushed onto the points and the points bent over so that they cut your hands when you reach in there.
        • Russ S.
          • April 30, 1982
          • 2162
          The clip on the left looks to me to be a hood insulation retainer clip on a steel bodied car. Probably a Mopar.
          • Bob R.
            • June 30, 2002
            • 1595
            The transmission tunnel insulation clips were used in mid years also. They are rivited to the fiberglass tunnel. The insulation gets pushed on and the clips get folded over to retain the insulation.
            • Monte M.
              • January 1, 1991
              • 687
              Thanks for the input guys.
              Terry, sounds like you have some first hand information there.
              No punn intended.
              How have you been? I have not talked to you in over twenty years.
              Do not expect you to remember me.
              Keep up the good work.
              Monte
              • Monte M.
                • January 1, 1991
                • 687
                My 63 did not have insolation in the tunnel, so I did not get the chance to use then on that car.
                Thank you for letting me know what they are.
