70 Coupe shoulder belt removal? - NCRS Discussion Boards
  • Mike F.
    • April 25, 2011
    • 668
    Is there a trick to get the black rubber/plastic off of the belt buckle? I've used a hair dryer, the plastic gets soft, but doesn't stretch enough to get over the buckle.
    Trying to get the belt out of the seat.
    TIA,
    Mike
  • Paul O.
    • August 31, 1990
    • 1716
    Re: 70 Coupe shoulder belt removal?
    Mike
    Even when heated it still takes quite a bit of force to get the buckle out. You might have to heat it several time as you force buckle through the narrowest point of the boot.
    Paul 18046
      • 6942
      Mike, I have boiled some water and put in a coffee cup and let it sit for about 30-45 Sec.s and have removed. will not damage.
