Changing PB Booster 1967 - NCRS Discussion Boards
  • Mark C.
    • May 5, 2009
    • 87
    OKSo I got my new PB Booster and it looks like a fairly easy swap however how do you reach the bolts under the dash? I have an AC car.
    Thanks for the help.
  • Gene M.
    • April 1, 1985
    • 4233
    Re: Changing PB Booster 1967
    Should not have to access hardware under dash to replace brake booster. Booster is secured to firewall via studs and nuts.
    • Mark C.
      • May 5, 2009
      • 87
      It looks like there are 2 studs that come through the firewall under the dash than need to be bolted. Am I wrong? (I hope)
      • Gene M.
        • April 1, 1985
        • 4233
        there are two more that are thru the area where the wiper arm grills are under the lip.
        • Mark C.
          • May 5, 2009
          • 87
          The top two are easy to access, Its the two that bolt through the firewall near the brake pedal that look "challenging"
          • W L.
            • January 19, 2011
            • 14
            It is a little "challenging", but isn't that difficult with the right tools. I suggest a socket wrench, the right length extension, and a swivel. Also, some Ben-Gay for your back. I've done it recently and I'm 67 and not much of a mechanic.
            Frank
            • Mark C.
              • May 5, 2009
              • 87
              Did you need to remove anything to get to the bolts?
              • W L.
                • January 19, 2011
                • 14
                Sorry Mark, I missed the fact that you car has a/c. Mine did not and that could make accessing the nuts much more difficult.
                Frank
                  With A/C, it will simplify the task if you remove the driver's side lower A/C duct - only takes a couple of minutes. That makes it much easier to get to the two lower nut & washer attachments.
                  • Mark C.
                    • May 5, 2009
                    • 87
                    John,
                    Thanks I will do that, when I looked under the dash I couldn't even find the bolts! I will tackle it tomorrow!
