1967 rear stabilizer bar - NCRS Discussion Boards
  • Lawrence S.
    • April 1, 1993
    • 801
    Was there an application where a small block would have had a rear stabilizer bar?
  • Dick W.
    • 10483
    Re: 1967 rear stabilizer bar
    Short, sweet, and simple, NO
    Dick Whittington
    • Lawrence S.
      • April 1, 1993
      • 801
      That is what I thought but wanted to double check
      • Gary B.
        • February 1, 1997
        • 7018
        Lawrence,
        Not in '67, but yes in '64 and '65.
        Gary
        • Ridge K.
          • May 31, 2006
          • 1018
          What about that short window of time in the '67 model year, when St.Louis ran out of small block hoods, .........and installed big block hoods on small bock cars?
          • Wayne M.
            • March 1, 1980
            • 6414
            Originally posted by Gary Beaupre (28818)
            (re: rear sway bar on small blocks) ... Not in '67, but yes in '64 and '65. ....Gary
            Gary -- not sure about 1964, but the only way to get a rear stabilizer bar on a '65 was to order L78. Didn't matter if F40 or std. suspension, the rear bar was the same 9/16" dia.
            • Gary B.
              • February 1, 1997
              • 7018
              Wayne,
              In '65 couldn't one get the rear bar with the L-84 engine option?
              Gary
                Gary
                Gary -
                Nope - only a larger front bar.
                  • 43219
                  Wayne,
                  Gary
                  Gary------
                  Until 1975 the rear sway bar was not part of any small block engine option or any suspension option. It was part of all big block engine options from 1965 through 1974. All bars were 9/16"
                  Beginning with the 1975 model year, it became part of the FE-7 suspension option but was a different bar than that used with 65-74 big blocks. The FE-7 rear bar was about 7/16"
                  • Bill M.
                    • April 1, 1977
                    • 1386
                    Gary------
                    FYI: The '75 and later FE-7 front bar got a lot bigger too, which kept a proper handling balance.
                      • 15667
                      1 1/8 inch
