I was told not to install my new restoration battery - NCRS Discussion Boards
  • Ronald L.
    • October 18, 2009
    • 3248
    #31
    Re: I was told not to install my new restoration battery
    Update -
    This battery we are working on is an antique auto batt.
    With a hair dryer, I warmed the shiny top surface and it is real easy to get that layer off.
    The smell is like road asphalt.
    There is another layer below that - same shiny - but I'm not sure its a good idea to take that one off, its almost like that one is holding the whole thing together.
    I also exposed some white hot melt on the inner sides and this is highy questionable if its the same type of construction as the Restorer article.
    Michael, I shot you an email - was interested to know the tar details a little better, now its not clear we can even do this the way this one is constructed.
    • Michael G.
      • November 12, 2008
      • 2158
      #32
      Hi Ron,
      I haven't worked on mine since the pics were taken last week. I stopped because I also have some concerns as to whether the Optima is too high to get the cables between it and the bottom surface of the battery shell. I measured it earlier and thought I could hog it out enough to make everything fit, but now I'm not so sure. Its going to be close, as the repro battery I used may be a different inside depth than the battery used in the restorer article. We'll see.
      I'm out of town until next week, but I will continue then and report back....
      Worst case is I have to switch to a smaller battery...
      Mike
      Mike
      1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
      1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
