68 BB Oil Pressure Line source-Steel - NCRS Discussion Boards
  • Patrick N.
    • March 10, 2008
    • 954
    I have been searching the usual places for a correct oil pressure line which I understand should be steel w/ natural finish, from engine fittings to bracket, and braket to gauge per TIM&JG. I can locate a copper tube, but not one in natural steel. Does anyone know of a resource for a correct steel line for this application?
    My understanding is the copper lines will work-harden over time from vibration and fail (that could be myth and I'm dead wrong),
    Pat
    68 427 400
    88
    • 43222
    Re: 68 BB Oil Pressure Line source-Steel
    Pat
    68 427 400
    88
    Patrick------
    Copper tubing was never used for Corvette oil pressure lines, although some of the tubing was steel with a copper plating.
    I believe that Dr. Rebuild, Paragon, or Corvette Central carries a good reproduction of the line used for your application.
    • John C.
      • January 1, 2005
      • 616
      Patrick
      I know there will be people who disagree with me but I think the description in the JG for 68's is completely wrong. In my opinion no steel line or bracket was used. Line was plastic and it attached directly to the bushing in the block. You can see a picture of what I consider the correct configuration in this earlier post. The plastic line should be black.
      https://www.forums.ncrs.org/showthre...80133&uid=1959
      John
      • Patrick N.
        • March 10, 2008
        • 954
        Originally posted by John Carlson (43123)
        Patrick
        John
        Joe and John, thanks, Great information as usual. John, has there been further discussion on the steel line vs plastic line for 68 in the JG? Thanks for the insight on the fittings as well, you just saved me from my next headache.
        Joe, thanks, I did come across similar info that in some cases GM used copper plated steel lines but never copper lines. I searched the sources mentioned, Paragon supplies this part to CC and it looks like they are plastic. I will call the Dr tomorrow to see what they offer.
        Best,
        Pat
        • Jim T.
          • March 1, 1993
          • 5351
          My 1968 original owner 327/350 L79 still has the factory installed black plastic oil pressure line.
          • Larry M.
            • January 1, 1992
            • 2695
            I believe that the "black plastic" is nylon tubing. It has very good oil, chemical, and heat resistance. I used in some of my early (non-Corvette) cars when installing SW gages. Still available.
            Larry
            • Patrick N.
              • March 10, 2008
              • 954
              Larry
              Larry- a little off topic, but when you SW gauges- are you referring to Stuart Warner?
              • Larry M.
                • January 1, 1992
                • 2695
                Yes.........I probably should have just spelled it out (Stewart Warner). Back in the 50's, 60's, and 70's they were the standard.
                Larry
                • Terry B.
                  • August 31, 1999
                  • 607
                  '68 Big Blocks used the steel line as Joe mentioned where small blocks used the black plastic line. My BB has the original steel line (looks like copper but that is just a coating).
                  Terry Buchanan
                  Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
                  Corvettes Owned:
                  1977 Coupe
                  1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
                  2003 Electron Blue Coupe
                  2019 Torch Red Grand Sport Coupe
                  • Patrick N.
                    • March 10, 2008
                    • 954
                    If I were to use the copper plated steel line, would the line from a 67 BB fit on a 68 BB- should be the same motor essentially? Bair's has the line for the 67- not 68. CC, DrR & Paragon no longer have the steel lines.
                    This part may be added to the "What's the hardest part to find" thread.
                    Thanks for the help.
                    Pat
                    • John C.
                      • January 1, 2005
                      • 616
                      Can you post a picture of what you have? I've always had my doubts that 1968 BBs used a steel line and bracket, but it is hard to find left alone cars. The steel line and bracket certainly isn't supported by what is shown in the AIM.
                      John
                      • Kenneth T.
                        • March 23, 2008
                        • 631
                        Is the oil line a judged item?
                        • Terry B.
                          • August 31, 1999
                          • 607
                          Hi John,
                          I have attached a picture of my oil line.
                          Kenneth,
                          I did not see an area on either the mechanical or chassis judging sheet that mentioned the oil line specifically.
                          Terry Buchanan
                          Corvettes Owned:
                          1977 Coupe
                            • 15601
                            Kenneth,
                            An item does not need to be specifically mentioned on the judging sheet in order to be judged. If we had to specifically mention each and every part on the car, and the judge had to examine each and every part -- consider:
                            1) how lengthy the score sheets would be.
                            2) how lone the judging process would be.
                            3) how much thicker the TIM&JG would be.
                            I judge the oil pressure line (BB & SB) when I judge the firewall. Others may assess it on other lines.
                            • John C.
                              • January 1, 2005
                              • 616
                              Hi John,
                              Kenneth,
                              Thanks for the picture. How far does your steel line go? All the way to the gauge or does it stop at a bracket as described in the JG? The oil line description is on page 68 of the RD (purple cover) edition of the JG.
                              John
