C1 clutch - NCRS Discussion Boards
C1 clutch
  • Philip P.
    • February 28, 2011
    • 558
    C1 clutch
    I am looking to replace my clutch this winter thinking of a LuK 04-084 any other recomendations.
    1960/ 230
    Phil
  • Donald M.
    Infrequent User
    • March 1, 1985
    • 28
    • Philip P.
      • February 28, 2011
      • 558
      Re: C1 clutch
      Thanks Don, I have heard pretty good thing about LuK clutches thanks for the reminder about the flywheel it was in the plan.
      Phil
        Re: C1 clutch
        1960/ 230
        Phil
        Phil -
        I put LuK RepSet clutches (from Paragon) in both of my 57's many years ago, and they're excellent; I'd do the same thing again if I needed a C1 clutch.
        • Philip P.
          • February 28, 2011
          • 558
          Re: C1 clutch
          John, I looked on Paragon site they have the 3 finger type for the C1 I assume the LuK 04-084 that is in the LuK catalog is the diaphram type for later (1963)small block cars but should work in a 1960 283.
          Phil
          • Thomas H.
            • August 31, 2005
            • 1068
            Re: C1 clutch
            If you guys used a diaphram type pressure plate, did you reinstall the gorilla spring?
            Tom
            2007 Z06, Lemans Blue
            • Philip P.
              • February 28, 2011
              • 558
              Re: C1 clutch
              Tom,
              My clutch was replaced sometime in its early life before I got it. The godzilla spring was replaced with a more "friendly" one. John Hinkley did an article I think on the Corvette Restoration site I will see if I can find it tells all that is required which is basically a hardware store door spring.
              I have not have any issues with the pedal but then I am not in the high speed shifting and such anymore, well not much anyway.
              Phil
                Re: C1 clutch
                Phil
                Phil -
                Paragon offers a 3-finger/coil spring Borg & Beck-type 10.5" replacement, but I don't know why anyone would want one; the other diaphragm offering is a 10.5" LuK (or it used to be), and that's the one I've chosen in the past; it works for any C1, and small-block C2/C3's through 1968.
                  Re: C1 clutch
                  Tom
                  Tom -
                  I didn't - I made an offset bracket that bolted to the same two holes that attached the original upper bracket for the over-center "Godzilla spring", and found a storm door spring that was just the right length to connect to the original frame bracket and function as a return spring to hold the pedal up against the rubber bumper. Or, you can just run a spring straight back to the firewall like the midyear setup. The diaphragm clutch doesn't need the over-center pedal-assist feature.
                  • Thomas H.
                    • August 31, 2005
                    • 1068
                    Re: C1 clutch
                    Tom -
                    John,
                    Good idea. I might give it a try. I put a diaphram pressure plate in and have been running it without a return spring with no issues other then the pedal doesn't stay against the bumper. Looks like a good project for this coming weekend.
                    Tom
                      Re: C1 clutch
                      John,
                      Tom
                      Tom -
                      I'd get a functioning return spring on it ASAP, before you fry the throwout bearing - that's not a fun job to replace.
                      • Philip P.
                        • February 28, 2011
                        • 558
                        Re: C1 clutch
                        Tom,
                        Whoever replaced my spring just put a less aggressive one in place of the original spring. I am not sure where they got it from , but is does work. I can remove it by locking on a pair of vice grips, it has a bit of tension but nothing like the original from what I can gather.
                        Phil
