1963 Steel Wheel Date Code and Such - NCRS Discussion Boards
  • Stephen B.
    • April 1, 1988
    • 876
    1. Where do you find the date code on steel wheels?
    2. What's the Kesley Hayes code for the wheels? Is it inside the wheel?
    3. Is there a difference in early and late wheel codes?
  • Harry S.
    • July 31, 2002
    • 5295
    Re: 1963 Steel Wheel Date Code and Such
    Answer: inside the wheel
    Yes
    Not that I know of
    Is there something more specific your looking for? Check the archives for pictures of physical attributes of the wheel, inside and out. I also believe there are some pictures of the KH logo and date code.
    • Stephen B.
      • April 1, 1988
      • 876
      Thanks Harry. A friend of mine wanted to know if his wheels were original. What's the Kesley Hayes code? Is it 15X5 1/2 K?
      Thanks again.
      Stephen
      • Tom H.
        • December 1, 1993
        • 3440
        Stephen. Here is a 63 64 wheel date code. You will find some that are not dated and some that are actually incorrectly dated too.
        Tom Hendricks
        Proud Member NCRS #23758
        NCM Founding Member # 1143
        • Tom H.
          • December 1, 1993
          • 3440
          I did not take this photo, but I use it often when this comes up. A 63 64 wheel is the one on the bottom. Pretty easy to spot compared to the replacements. There are some other good posts on this subject here. If you can't find them, let me know. I will search them out for ya !
          Tom Hendricks
          • Tracy C.
            • July 31, 2003
            • 2739
            Thanks again.
            Stephen
            Stephen, The wheel code is 15X5 1/2 K for all 63 and 64 wheels. The pic Tom posted of the two wheel configurations is one I put together to depict the difference between an original 63/4 wheel and the more common 8080 service replacement wheel. The 8080 wheel appears otherwise identical to an original 63/4 wheel and they are frequently listed on ebay as "original" 63/4 wheels. Good 63/4 exterior judges know the difference because the back side is visible when mounted on the car.
            tc
            • Stephen B.
              • April 1, 1988
              • 876
              Thanks for all of your help gentlemen.
              • Harry S.
                • July 31, 2002
                • 5295
                I'm not selling these, but there are some good pictures.
                • Ronald L.
                  • October 18, 2009
                  • 3248
                  For clarity, the 15x5 1/2 K is the wheel size.
                  Below that are the date codes...
                  • Stephen B.
                    • April 1, 1988
                    • 876
                    I thank all of you for your input.
