I just finished installing new window inner, outer seals and felts and anti rattle cushions. Prior to the new parts being installed both power windows operated normally - although they rattled a lot due to old worn out parts. Now the system is so tight that I need to pull up the windows to assist the motor in closing. Clearly things are now to tight for the motors. Is there some adjustment I can to do? Any suggestions would be appreciated.
