A/C compressor 69 - NCRS Discussion Boards
A/C compressor 69
  • Anthony C.
    • April 5, 2007
    • 81
    A/C compressor 69
    I am looking for a compressor for my Nov 69 build. How do I go about getting a correct one for the car. I have seen several old compressor that would need to be rebuilt. Can they be rebuilt to function correctly?How do you determine the production date for one? I want to continue to run R 12 when car is completed not convert over to R 134.
    • 6960
    Re: A/C compressor 69
    Anthony, I believe that the A-6 compressors where were much alike and that there was a casting date on the rear of the compressor ( where the manifold and hose bolts up).There is also a label on compressor that had a part no. and the date it was manufactured. The problem with the repro label is the comes blank and you need a typewriter with the correct sized font.
    • William C.
      • May 31, 1975
      • 6037
      The truly unique compressors were on the 63-65 cars where the case was swedged at the front rather than welded. Otherwise, parts is parts as they say.
      Bill Clupper #618
      • Anthony C.
        • April 5, 2007
        • 81
        So the casting date is not visible with the muffler and hoses hooked up? So besides correct looking foil labels for a 69 and typical compressor for a 69 is all I would need to have to pass judging?
        • William C.
          • May 31, 1975
          • 6037
          You would have to look at one to see if the casting date is visible installed in a car.
          Bill Clupper #618
          • Domenic T.
            • January 29, 2010
            • 2452
            Anthony,
            The date is on the back plate and dated like most of our parts here is a pic of one.
            I have a A 6 9 , Jan 6th 1969.
            DOM
            • D S.
              • March 1, 2005
              • 1551
              Originally posted by Domenic Tallarita (51287)
              Anthony,
              DOM
              There's a picture?
              • Anthony C.
                • April 5, 2007
                • 81
                I will look at my compressors tomorrow and see what I come up with. Can these be rebuilt reliably?
                • Domenic T.
                  • January 29, 2010
                  • 2452
                  Originally posted by D Scott Sims (43568)
                  There's a picture?
                  Scott,
                  Thought I had it (the pic) but after 1/2 hour it won't( the computer) let me attach it to a new file.
                  I will try and get a NEW pic tomorrow.
                  DOM
                  • D S.
                    • March 1, 2005
                    • 1551
                    Scott,
                    DOM
                    Thanks, Dom. I looked at the back of compressor in my '70 and all I saw was some partially blocked out numbers and below that was L 26.
                    • Domenic T.
                      • January 29, 2010
                      • 2452
                      Could be Dec 2nd 1966
                      DOM
                      • Domenic T.
                        • January 29, 2010
                        • 2452
                        DOM
                        Scott,
                        If it has the thermal switch (1 prong) on the back plate it could be a 1976.
                        DOM
                        • D S.
                          • March 1, 2005
                          • 1551
                          DOM
                          It is supposedly original to the 1970 so perhaps a number is covered up by the rectangle compressor manifold.
                          • Domenic T.
                            • January 29, 2010
                            • 2452
                            Scott,
                            Here is the pic of the compressor backplate without the thermal switch.
                            Jan 6, 1969
                            DOM
                            • D S.
                              • March 1, 2005
                              • 1551
                              My '70 compressor is also a 6555302 but it has a casting date (?) of G-3 just under the manifold, then the part number, and below that is L 26. Another '70 owner has one that is A-3, Part #, and L-21. I have no clue what A-3 and G-3 means.
