High oil pressure
Re: High oil pressure
Were the main journals align honed? If your crank is small journal, then your bearing clearance should be .0021 +\- .0005. If the clearance here is on the small end of the range, your oil pressure will be on the high side.
You should be using Rotella in 10W-30 preferably, if not, then 15W-40.
The oil pump should have nothing to do with idle pressure when at operating temp since the high pressure pump relieves at 65-70psig and the standard pressure spring relieves at 55-60psig.
Actually,
Each different spring has a different low and high pressure, at all temps.
It would be nice that way but there is only a limited space for the spring in the pump.
So a stiff spring restricts the oil from bi-pass also at idle and is at full bi-pass only when fully opened.
DOM- Top
Wondering about the Renault F1 engine that turns 19,000 rpms. Rule probably does not hold true in modern racing engines.Dick Whittington- Top
