Well, I just passed 2000 miles on the rebuilt L79 in my '67 coupe. It shows extremely high oil pressure. It pegs the needle on start up at idle and the lowest I've seen is 55 lbs at idle after a 20 mile run. I checked it with another mechanical gauge and the readings appear right. I guess the re-builder put in the famous hi-volume/hi-pressure oil pump. When I originally got the car put together, it was real tight, and would overheat after idling for 5 minutes. After running a few hundred miles that problem went away. The engine starts and runs great, and now runs 160 all the time after warm-up (160 thermostat), and I have no complaints about anything else functionally.
A couple of questions :
1. Is there a possibility that this high oil pressure is harmful?
2. Would changing to a lower viscosity (I see 0-20 is available) with the proper zinc additive help any?
3. I am thinking of changing to a 180 thermostat because I think I may be running too cool now; would that be a good idea?
I don't race the car and don't run it all that hard. I did have a plug fouling problem, but that was solved by changing the AC 44 resistor plugs to a non-resistor AC 45 equivalent (Denso W14-U) and some carb tweaking.
Any help will be appreciated.
