C3 #4 body mount - NCRS Discussion Boards
C3 #4 body mount
  • John W.
    • February 1, 2006
    • 16
    C3 #4 body mount
    72 coupe - Bolt and cage nut on my number 4 mounts are rusted. Cage nut turns in the cage. A bear to get to. What is the best way to get the bolt out? I can buy a new cage and nut when I go back. Installing the riveted cage looks almost impossible.
    Jay
  • Pete B.
    • February 22, 2007
    • 328
    Re: C3 #4 body mount
    John, mine were the same...I burned off the bolt from the bottom (outside the car) The cage disintregated and I pulled the rest through the inside.
    Instead of putting a new cage nut in, I chose to put a nut, split lockwasher and a fender washer in.
    Bolt in from the bottom and it looks original. Once interiors in its covered.
    Pete Bergmann
    2005 - 2013 C6 National Teamleader
    • Graeme B.
      • October 23, 2007
      • 213
      If you take the cage off,you can put a socket on the square nut.I forget which size works.Good luck.
