Maintenance free batteries - NCRS Discussion Boards
  • Jerome P.
    • October 22, 2006
    • 607
    What kind of life can I expect from a "Restoration Battery" - maintenance free battery. I have had it for about 5 years but it has had very little use. When not in use I had it on a "Battery Tender" trickle charger. However, and it is big however, for two years it was not any type of charge.
    I am going to put it o a trickle charge tomorrow evening and hopefully it will charge up and hold a charge.
    Any thoughts on what I should expect?
    If it does charge up should I expect it hold the charge?
    I know these are hypothetical questions, but your thoughts will be appreciated.
  • Gene M.
    • April 1, 1985
    • 4232
    Re: Maintenance free batteries
    Jerome,
    Check the voltage with a volt meter. If not at least 12+ volts I do not have much hope for it.
    No loss to try the charge, but use low amp charge rate.
      • 11678
      6 years and still working for mine. It took me to the National at Novi and back this year in my 72. I'm pleased.
      Mine gets charged 2-3 times a year. Every time I stick it back on the trickle charger it's at "Full" in 15-30 minutes. So, I see little benefit in leaving it connected full time.
      I do keep my battery disconnected between uses.
      Patrick
      • Gary P.
        • May 31, 2005
        • 104
        Your battery will not take a trickle charge. Needs to be charged every two or three months at 10amp. ( no more ) charge for two hours.
          • 11678
          Mine takes it just fine.
