1958 Corvette Engine Compartment - NCRS Discussion Boards
  • Dennis G.
    • March 1, 1993
    • 100
    I have an early Corvette that came without the optional heater. My question is, it has a screen where the heater air inlet would normally be. Is that correct? The drivers side is open, without a screen or block off plate. Is that correct? I have attached pictures, the passenger side does not have the screen installed right now.
  • Bob H.
    • July 31, 2000
    • 821
    Re: 1958 Corvette Engine Compartment
    Hi Dennis:
    My 61 did not have a heater or radio. It was as you described. It was an untouched original car. so yours should be correct.
    Bob
    • Dennis G.
      • March 1, 1993
      • 100
      I found out from another source that 58-60 Corvettes had a solid plate on both sides of the car if it did not have Fuel Injection or a heater. The plates were not on when the engine compartment was painted. Like some other parts they were dipped in paint.
      My car had some front end damage and a replacement core support. That's probably the reason for the plates not being original.
      • Ronald R.
        • May 31, 1989
        • 671
        The 250 HP cars did not have the air hose and drivers side would be blanked
        RDR
