70 antenna - NCRS Discussion Boards
70 antenna
  • Mike T.
    • August 31, 1979
    • 122
    70 antenna
    Just bought a lift so I can double deck my vettes. Drove the shark under the lift, and the antenna hit the lift. Tried to disconnect the mast and couldn't do it.
    How do we disconnect the antenna mast from the base on a shark?
    Thanks.
  • Lawrence M.
    • February 1, 1995
    • 404
    Re: 70 antenna
    Mike,
    On my 69 (70 should be the same) the factory antenna mast is held on by a bezel or nut at the bottom of the mast . It has 2 flats on it that take, I think a 5/8 open end wrench. Unscrew the bezel and the mast should pull off.
    Larry
    2002 Z51 Convertible
    1969 L46 Convertible
    • Mike T.
      • August 31, 1979
      • 122
      Re: 70 antenna
      Thought so. I did that, and slid the chrome bezel up and off of the mast. I couldn't separate anything else. The long tapered stainless piece at the bottom of the mast seems like it should turn. I wrapped a piece of rubber around it, and used a pair of pliers. No luck.
      I ended up loosening up the big chrome retainer nut that sits on the quarterpanel, and letting the antenna fall down onto the muffler so I could pull the Shark under the lift.
      Can't believe this is so difficult.
      • Lawrence M.
        • February 1, 1995
        • 404
        Re: 70 antenna
        Mike,
        Your mast must be rusted to the anrenna base. It just pulls off. In the picture I attached you can see how deep the mast goes into the base. Also the mast has teeth that mate up to teeth on the base. Some penetrating oil and patience will hopefully free it up
        Larry
        • Jim T.
          • March 1, 1993
          • 5351
          Re: 70 antenna
          Thanks.
          Mike your mast should come out of the base as posted above. I have a 70 and a 68 and lifts. I leave my antennas off the cars. Local radio reception is good without the antennas.
          • Mike T.
            • August 31, 1979
            • 122
            Re: 70 antenna
            Now I know how to how to go about it. I'll get after it tonight.
            That was really frustrating. Gotta love NCRS!
            Thanks Larry and Jim!
            • Steven B.
              • June 30, 1982
              • 4010
              Re: 70 antenna
              Mike, I had the same problem on my '77. A little penetrating oil and waiting a day worked.
              'Done anything with the '57?
              Steve
              • Mike T.
                • August 31, 1979
                • 122
                Re: 70 antenna
                Thanks Steve.
                Been spending most of my time on the shark, but still accumulating 57 original parts. Just got a tach from California that is reallly nice, and a set of 9 fins. Got to be patient or I'll have to pay way too much for stuff.
                Just missed a set of 997's for $1,500! Believe it or not, a friend of ours sold them and didn't know we were looking for a set.
                • James Y.
                  Infrequent User
                  • January 1, 1996
                  • 9
                  Re: 70 antenna
                  Had the same problem with my 1973. It got a Duntov award and I never was able to get the antenna off. Good thing is, you don't have to worry about anyone steeling it.
                  • Mike G.
                    • July 31, 2002
                    • 709
                    Re: 70 antenna
                    sometimes they get stuck. i could not remove the original antenna on my 72. had to replace the entire thing.
