'58 270 Duntov oil pan: steel or aluminum? - NCRS Discussion Boards
  • David B.
    • July 7, 2011
    • 88
    Just did my first oil/filter change on my '58. I see a tiny leak forming on the drain plug. I may have been too conservative about tightening it.
    Anyway, my question: Is the oil pan on this engine steel or aluminum? If it's aluminum, I'll be extra careful about over-tightening. The rubber seal is fine.
    By the way, the drain plug is on the driver's side of the pan, somewhere near the middle. Is that a clue about steel or aluminum?
    Thanks, guys.
    Dave
  • Robert B.
    • December 1, 1999
    • 56
    Re: '58 270 Duntov oil pan: steel or aluminum?
    Not exactly sure about a '58, but my '60 270 horse has a steel "trap-door" pan. I'm not the expert, but I don't think any C-1 had an aluminium pan. Hopefully someone more knowledgable about the 58 will chime in .
    • Steven B.
      • June 30, 1982
      • 4004
      Pan is steel if stock.
      • Joe R.
        • July 31, 1976
        • 4551
        Don't think you will find an aluminum pan on ANY REAL Corvette. That was the time period prior to 1967. Yeah, Yeah!
        JR
        • David B.
          • July 7, 2011
          • 88
          Thanks, guys. I think a magnet might also confirm steel over aluminum. Don't know why I didn't think of that sooner. Duh.
          Dave
          • Gary C.
            Administrator
            • October 1, 1982
            • 17789
            David,
            Recommend you do a "search" of the forum for oil pans. Lots of info and photos/drawings previously posted on C1 oil pans.
            BTW, C1 V/8 oil pans are steel. And all the drain plugs are located in the middle rear of the flat portion of the oil pan, not on the side.
            Gary
            NCRS Texas Chapter
            https://www.ncrstexas.org/
              Dave -
              Answered your post on CF with photos.
