68 Coupe Carpet Question - NCRS Discussion Boards
  • Mark F.
    • January 1, 2003
    • 139
    I'm replacing the carpet in my 68 coupe and I threw out the old carpet as it had mold on it. The new carpet didn't come with a pre-made hole for the headlight dimmer switch on the driver side floor. Can someone help me out here and advise if I just need to cut a hole or is it supposed to be a manufactured hole with trim sewn around it. I got the carpet from Al Knoch. Thanks in advance.
    (I know, never throw anything out)
    Mark
  • Dick W.
    • 10483
    Re: 68 Coupe Carpet Question
    Unless you have something I have not seen, there is NO hole for the dimmer. There should be a hinged hard plastic piece over the dimmer switch. The carpet covers the plastic piece and you just press on the carpet to dim the lights.
    Dick Whittington
    • Mark F.
      • January 1, 2003
      • 139
      I'm missing the plastic piece. Thank you for the reply as that now makes sense. Mark
