Intake Guard/Shield - NCRS Discussion Boards
Intake Guard/Shield
    • 43246
    Re: Intake Guard/Shield
    Originally posted by Clem Zahrobsky (45134)
    here is the GM heat shield for BBC intakes. http://www.gmpartsdirect.com/perform...CATID=611.html
    clem-----
    I think this shield was only used on L-88 big blocks and I'm not 100% sure it was even used on that.
      • 43246
      i always wondered if that shield really did any good because if you take one off it is full if burnt oil. i would think the oil would be better off just hitting the manifold and falling back down. JMHO
      come to think of it the aluminum intake on BBC had no shield riveted on.
      clem-----
      Some big blocks have the shield. The LS-6 manifold definitely did. I believe the 1968-69 390 HP aluminum manifolds did, too.
      • Jim D.
        • 2884
        #18
        i would drill and tap for a machine screw and use red locktite. once you take out those rivets i would worry the new ones in the used holes could come out and fall into the engine
        Yup. Just did this today. Drill and tap for a 10-32 machine screw and install with red Locktite.
        • Clem Z.
          • January 1, 2006
          • 9427
          #19
          clem-----
          it is a over the counter piece for race cars. i just posted this to show how they cover the whole bottom to keep the heat off of the intake runners for better fuel distribution.
          • Clem Z.
            • January 1, 2006
            • 9427
            #20
            clem-----
            if i remember correctly the 3947084 and 083 did not have the shield. i wonder if the ones you mentioned had it because they were of the low riser design and the underside may have be different than the 083/084 manifolds
            • Rich C.
              • January 1, 1994
              • 383
              #21
              My '73 454 cast iron intake uses one! It's factory.
              '73 LS-4 454 owned 21 1/2 years
              • Loren L.
                • April 30, 1976
                • 4104
                #22
                Well, whatever they're used on, you might want to check out Bill W.'s source because if you buy them from the General, list is $5.60 each, trade at $4.20 - my extras are going under lock and key with my spare FI parts.
                You know the place - where you left the note to your wife that reads "Do not sell these parts for what $$ I told you I paid for them. Check with _________ first!!"
                  • 43246
                  #23
                  clem-----
                  Yes, I think the low profile design of the manifolds I mentioned was probably the biggest factor in their being equipped with the shields.
                  • Ralph P.
                    • February 1, 1990
                    • 253
                    #24
                    I'm missing the shield under my 67 400 Alum intake....... What's the best source?
                      • 43246
                      #25
                      Ralph------
                      It won't be easy. The intake manifold GUARD (shield) for your application, GM #3894378, was unique to the 1967 Corvette with L-68 and L-71 applications. It was not used for any other Chevrolet or GM applications. It was discontinued without supercession in June, 1974. I'll bet there was not a dealer in the country that stocked this part then and now it's 37 years later!
