Fan Clutch: Who sells originals???? - NCRS Discussion Boards
  • William H.
    • January 1, 2006
    • 209
    Can anyone direct me to where to find a fan cluch for a 1968 427/435? Who sells them? Thanks for any help. Bill
    Bill Hyndman
    The 'Sound of Freedom' if not a UH-60 Blackhawk, then it must be a Corvette!
    1962 Big Brake Fuelie
    1965 Fuelie Convertible
    1968 L89 Convertible
  • Mark D.
    • June 30, 1988
    • 2144
    Re: Fan Clutch: Who sells originals????
    When was your car built?
    Kramden
    • William H.
      • January 1, 2006
      • 209
      Car was produced Jan 3, 1968. Engine is Dec 16, 1967. Thanks if you can help. Bill
      Bill Hyndman
      • Grant W.
        • December 1, 1987
        • 407
        Well in my collection I don't have an early 67 date. I might have had one a while back but I think it went to an NCRS member.
        Hard date to find especially a 67 late date.
        Funny thing is I started to collect fan clutches about 20 years ago for my 69 435hp car which is long gone and I haven't stopped collecting....I think I better stop.
        Grant
        • Larry M.
          • January 1, 1992
          • 2688
          Bill:
          Close reproductions are available for reasonable cost. Paragon and others sell them. Check the archives for the recommended GM/AC/Eaton part numbers....or trust Paragon to provide. The reproductions usually judge well, with maybe a few point max deduction.....plus they are new and function as new.
          You can also make Grant an offer ($$$) he can't refuse.
          The Eaton coil clutch used ink stamped codes, so you can make up a stamp if you desire.
          The DRIVELINE also lists a few rebuilders of these units.....you could call them and see if one is available for sale. They usually are. I know, as I bought one from Fred Oliva (early rebuilder) for my 1967 car about ten years ago. I think Fred still does this work, but generally has a LONG backlog and wait time.
          Larry
          • Ridge K.
            • May 31, 2006
            • 1018
            Grant
            You know it's an addiction, don't you Grant?
            I have it also.....
            Ridge
            • Chester K.
              • July 2, 2009
              • 32
              Hello Grant,....I am researching the Schwitzer fan clutch date code format, so I will appreciate your input. Tell me, is the date code format stamped on the Schwitzer fan clutch mounting flange, SC dd.mm.yy, or is the SC after the date......Thank you for your input.....Chet
              • Grant W.
                • December 1, 1987
                • 407
                Hello Chet
                I have original 65 66 fan clutch with the format as follow SC dd.mm.yy
                I have a late 66 dated 12 13 66 and formatted 12 13 66 SC
                All my early 68 and 68 69 70 71 72 is formatted dd.mm.yy SC
                73 74 75 is formatted Alphabet mm yy SC
                Hope this helps
                Grant
                • Rick N.
                  • August 25, 2017
                  • 141
                  Kirkconnel Corvettes 813-477-5128
