Morning, I searched for correct cable markings but came up empty. On 68's march build should there just be a  P and an  N   on the top side besides the spring ring words for correct cable heads ? thanks in advanse. Jeff
					1968 Spring Ring Battery Cables
Re: 1968 Spring Ring Battery Cables
Jeff,
I recently sold a pair of NOS GM # 2978482 spring ring ground (negative) cables (30" long) for various 64-70 Pontiac models according to my 1971 Pontiac Parts Catalog.
The spring ring part was "embossed" with the following: "SPRING", "RING", and "GM" (see photo). The black cable had "DELCO PACKARD - IT30" printed in white.
The flap on one of the boxes was dated "3-69" (March 1969).
These cables were service cables and were not necessarily the same as the factory installed cables. I have an original spring ring cable from a 1965 Chevrolet 396 but it looks like it went through a war.
DaveAttached Files- Top
Jeff
On my April built car the cable only has a P and N on the side with the spring ring text. The text is on the round barrel of head.
John- Top
Thank you, David and John. Great help. Question for John. On the negative cable do you have 5070 in white ink around 8" from the head ?68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
2014 Arctic White Z51 Vert. (Wifes)- Top
The number "5070" is the last 4 digits of the GM part number 6295070 (ground cable) as shown in the 1968 AIM (UPC 12, sheet A12). It's not rocket science.
Dave- Top
