How best to display at NCRS meet? - NCRS Discussion Boards
  • Tory S.
    • 146
    It's been many years, a lot of time and money, but I'm finally finished (at least for now) with my full body-off restoration of my '75 convertible. Now it's time to get it judged, but I've never done this before!
    What is the best way to display a C3 at an NCRS meet? Any and all advice or tips are welcomed; what to do and not to do. I'm entered in the Texas Regional the end of October and I could use all the advice I can get.
    I also want to thank so many of you for your great advice over the years on my project, especially Joe Lucia, Alger Rutz, Patrick Hultz, Terry McManmon, Lyle Chamberlain, John Hinkley, Raymond Wells, Peter Lindahl, Tom Russo, John Waluk and so many, many more.
    Tory
    1975 Convertible
    L-48, 4-spd, FE7, radio delete
    Original owner
    NCRS Top Flight Regional 2011, 2013
    Dallas, TX
    Re: How best to display at NCRS meet?
    Tory -
    Do you have the 8th Edition "Corvette Judging Reference Manual"? It describes the judging process in detail, including an "Owner's Advisory" section that describes what to expect and how to prepare. It's available from our NCRS on-line store at the "NCRS Store" icon in the blue line at the top of the page.
    • William M.
      • July 31, 1993
      • 390
      Go through the Technical Information Manual & Judging Guide page by page and self-judge your car. Make sure everything works, as points lost on Operations can really add up. An NCRS decal, battery cut-off and fire extinguisher will get you 10 easy points. Don't worry about the small details at this stage, they're not worth a lot of points. Focus on the big items, like tires being correct brand and size, or battery being AC Delco.
      Don't stress too much, have fun and good luck!
      Bloomington Gold 2011
      Corvette Magazine 9/11
      Bloomington Gold 2013
      Corvette Magazine 3/13
      • Tory S.
        • 146
        Thanks John. I ordered the book last night. I'm sure I'll be a lot smarter soon.
        William: Thanks. Great details. Already have the NCRS decal and cutoff. I'll take an extinguisher from another car. I'll change my battery to Delco and as for tires, I have the original Firestone Steel Radial 500s. Should be good there. too.
        If you think of any other great tips, let me know.
        Tory
        1975 Convertible
        Original owner
        Dallas, TX
        • Peter G.
          • December 1, 1980
          • 406
          Tory..as a Judge and Owner I like to have the car ready for judging. I mean having all personal items out of the car..floor mats, garage door opener and guns!
          Spare tire should be out and down behind car, Jack and Owner's Packet out of the glove box. Under hood, Air Cleaner off and Ignition Shielding over Distributor only off.
          I like to provide my own matching fender covers.
          If you do all this..the judges would be SHOCKED that it is your first time!
          Good luck with the car.
          I am attending the TX Regional also so I look forward to meeting you. (I usually hang out around the Flight C3 cars anyway after checking out the other Corvettes).
          Peter Gregory # 4157
          National Corvette Restorers Society Since 1980
            Tory -
            The best way to spend your free time at this point is on the Operations section - there are 750 points there, and almost every item is pass/fail, 25 points at a crack (it takes a LOT of onesy-twosie deductions in other areas to equal just ONE Operations deduction). Learn how to start the car correctly from cold, and make sure your fast-idle system is engaging and releasing properly.
            • Reba W.
              • 938
              You can obtain sample judging sheets online so you, and perhaps a friend or two, can do a practice judging.
              As an interior judge, I second what Peter said about getting all the personal stuff out of the car.
              • Michael J.
                • January 27, 2009
                • 7166
                I found it very helpful when I was a newbie to go through chapter judging before a regional, so many things you will miss on your own without any judging experience.
                • Tory S.
                  • 146
                  Ya'll are a great help.
                  As for the owner's packet Peter mentioned, since I'm the original owner and have all the original documents in clear sleeves in a 3-ring binder, should everything be taken out and packed into the clear owners envelope, or would the judges like to just leaf through the binder to see everything better?
                  I've downloaded the judging sheets and will concentrate on Ops. Thanks.
                  As for Micheal's sound advice of showing at Chapter before Regionals, well I wasn't finished before the chapter meet, so I figured I'd just dive into the deep end of the pool!
                  Tory
                  1975 Convertible
                  Original owner
                  Dallas, TX
                  • Bill C.
                    • June 25, 2007
                    • 106
                    Tory-
                    I would leave all your documents in the binder. Have the binder ready to show the judges. I have had my car judged three times. Only once did a judge ask me to take an item out of the plastic.
                    Good luck at the regional;
                    Bill
                    • Chris E.
                      • November 3, 2006
                      • 1335
                      Tory,
                      When you get the car to the Regional, and have done all the prep work the others have suggested (pulling down the spare tire, taking off the ignition shielding, etc), BRING A PEN AND PAPER. When the judges go over the sheets with you, TAKE NOTES.
                      If you are not planning on campaigning the car any further, then you wouldn't need to worry about taking notes. But if you, like me, want to continue to improve the car and make it as good as it can be, you'll need to take notes.
                      Also, have an open mind. The judging that you'll receive at the Regional Level will be great. But no one is perfect. Before you make any drastic changes to the car, ask a lot of questions. Sometimes () judges aren't right about a particular detail. However, having said that, know this. I have had my car judged four times for Flight (twice at the Chapter level and twice at the Regional level). All four times, the comments I received and deducts I received were within a fairly tight range of one another.
                      Oh, and have fun. That's what this is all about.
                      Chris Enstrom
                      2011 Z06, red/red
                      • Tory S.
                        • 146
                        Chris,
                        Is there a way to get copies of the judging sheets too? That would go a long ways in coordinating with my notes.
                        Tory
                        1975 Convertible
                        Original owner
                        Dallas, TX
                        • Don H.
                          Moderator
                          • June 16, 2009
                          • 2282
                          you will receive your judging sheets in the mail a couple weeks after the meet. NCRS does not keep them.
                          I would add regarding notes. The judges should note any deviations on the sheets, especially ones that cost points, but sometimes they write like doctors,
                          or shorthand in ways that will have you scratching your head later as you try to recall what they dinged you on.
                          • Carl N.
                            • April 30, 1984
                            • 592
                            Tory,
                            If I had to chose between the chapter meet at the speedway and the regional at Frisco - I'd go with Frisco - you'll do fine - just relax
                            Not knocking the chapter meet, but you'll have a better set of sheets to build off of for the future from Frisco.
                            Be carefull if you are driving over on original "Stones"
                            See you there !
                            Carl
