1994 Automatic Transmission Leak - NCRS Discussion Boards
  • Brad L.
    • August 12, 2009
    • 5
    I need to research getting the automatic transmission rebuilt for my 1994 Corvette. The Chevy Dealer in Dallas suggested buying a completely refurbished GMC transmission for 1700.00. Labor 585.00, but I want to keep the original transmission so the numbers match. I had the seals, bushing, pump and converter replaced 17,000 miles ago due to severe leaking. Now the tranny is leaking agian. Does anyone have any suggestions?
    Thanks, Brad
  • Tom H.
    • December 1, 1993
    • 3440
    Re: 1994 Automatic Transmission Leak
    Welcome aboard Brad !
    Are you trying to stop a slight drip or a severe leak ??
    I would have a different dealer or transmission shop look at the unit and determine the cause of the leak before replacing the unit.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Brad L.
      • August 12, 2009
      • 5
      I'm trying to stop a slight drip but it is getting a little worse.
      • Keith B.
        • March 7, 2008
        • 928
        Mine leaked when I bought it. it turned out the be the o-ring on the the speed sensor. replaced now its leak free
        • Brad L.
          • August 12, 2009
          • 5
          Is the speed senor o ring easy to get to? It is in the shop now. They said it looks like it is leaking from the pump area.
          • Keith B.
            • March 7, 2008
            • 928
            Very easy to get too. But a pain to remove
            • Brad L.
              • August 12, 2009
              • 5
              Thanks for the tip. I will check it out.
              • Richard M.
                • April 1, 1993
                • 198
                Try Plano Automatic Transmissions 972-423-3666 Jimmy Hooten will get you fixed up, these guys a great.
                • Brad L.
                  • August 12, 2009
                  • 5
                  I would like to thank everyone for the quick responses to my question.
