1966 Alternator Pulleys - NCRS Discussion Boards
+ More Options
Posts
  • Robert T.
    • May 31, 1993
    • 346
    Could someone please tell me what the visual differences are between the 3829387 and the 3829193 alternator pulleys used in 1966. Not sure which one I have on my L72. No PS, No AC.
    Bob
    • 43282
    Re: 1966 Alternator Pulleys
    Bob
    Bob-----
    Although both are the same 3-5/8" OD, the 3829193 is a thicker pulley. It has, effectively, a "spacer" built in which occupies the space of one pulley groove. So, it results in the belt being spaced out one groove's width.
    The 3829387 is a thinner pulley. It has a much thinner "spacer" on the inside end.
    • David L.
      • July 31, 1980
      • 3310
      The thread listed below might help. I have a detailed drawing of the 3829193 pulley if you need a photo of it.
      Dave
      https://www.forums.ncrs.org/showthre...=7177#poststop
      • Robert T.
        • May 31, 1993
        • 346
        Thanks for the info Joe, and Dave.!! Appreciate you taking the time to reply.... and thanks for the link to the earlier thread. Never knew that there was so much discussion on these crazy pulleys.
        Dave, could I take you up on your offer of a copy of the 3829193 pulley. Any chance you have a copy of the 3829387 also.
        Bob
        • David L.
          • July 31, 1980
          • 3310
          Bob,
          Here are my drawings that I drew back in the early 1990's.
          Dave
          • David L.
            • July 31, 1980
            • 3310
            Bob,
            I got this drawing from the NCRS Forum but I do not know the thread name.
            Dave
            • Robert T.
              • May 31, 1993
              • 346
              David, thank you very much!! Thanks for doing all this for me. Really appreciate it. It looks like I have a 3829387 on the car, which I believe is correct based on a L72 w/o PS, or AC (obviously). The current JG says I need a 3829193. I doesn't mention PS, which I think it should. That's what got me started. I think the usage table in the JG will need to be expanded upon, and corrected.
              Thanks again for the pictures.
              bob
              • David L.
                • July 31, 1980
                • 3310
                Bob,
                The 3829387 pulley that I owned back in the early 1980's that I removed from an alternator dated sometime in February 1966 was stamped "3829387-AI" on the front surface.
                Dave
                • Michael H.
                  • January 29, 2008
                  • 7477
                  Originally posted by David Liukkonen (3775)
                  Bob,
                  Dave
                  The 3829387 alternator pulley on my November 65 built 66 does not have a part number stamped on it.
                  If I remember correctly, there is a note on the GM print that mentions that the part number stamp was added at some time in late 1965?
                  I'm not sure if any 396 cars with the 3829387 pulley originally had the part number stamped.
                  • Robert T.
                    • May 31, 1993
                    • 346
                    Mike,
                    How close is your car to a Sept 23,1965 assembly date? That's when my #1478 was built.
                    bob
                    • Michael H.
                      • January 29, 2008
                      • 7477
                      Mike,
                      bob
                      Bob,
                      My 66 is about two months later. Late November, 65.
                      I just noticed that my previous post stated that my car was built in Sept 65. That should have been November 65, not September. I corrected it. Sorry.
                      • Robert T.
                        • May 31, 1993
                        • 346
                        No problem. Thanks for the reply
                        bt
