62 FI Accelerator Lever Ground - NCRS Discussion Boards
  • Stephen G.
    • January 1, 2002
    • 305
    Should there be a washer under the screw that attaches the ground strap to the accelerator lever? The AIM shows part # 446161 P.W. between the screw and the ground strap. Perhaps this is a spacer, not a washer.
    My car has a washer between the screw and strap. I got a deduct at the regional with a note saying "should not have washer under Gnd Strap screw".
    Steve Gansky
    Newtown, (Bucks County) PA
  • Mike E.
    • February 28, 1975
    • 5141
    Re: 62 FI Accelerator Lever Ground
    Regional judge should have his knuckles rapped--there is definitely a washer under the screw. Could it be that judge is trying to indicate the washer is incorrect diameter or some other issue with it?
    • Alan D.
      • January 1, 2005
      • 2053
      Steve the PW = plain washer. I only show a 446363, 3/8" PW, sure that number is correct? My book on washers is very very limited so the pn may be fine.
      The 62 Service Guide calls, Accessories 13-7, for a plain washer.
      Not very knowledgeable on 62, however that washer is a constant source of disagreement on C2.
      • Stephen G.
        • January 1, 2002
        • 305
        Thanks for the input. I have a "plain washer" of correct size for that screw. I'll see what happens next time I get it judged.
        Steve Gansky
