54 speedometer cable/gear - NCRS Discussion Boards
  • Robert K.
    Infrequent User
    • January 1, 2000
    • 29
    My cable was stuck in the transmission speedmeter gear. I cut the cable and unscrewed the gear assembly from the transmission housing. I don't see how the plastic gear separates from the metal assembly housing, and I haven't been able to get the cable stub out of the fitting. Advice?
    What is the gear assembly called, or what is the GM part number so that I can find a replacement?
    The parts catalog lists a replacement cable under category 4.342 as PN 1562669 and states the cable length to be 63 5/8 inches. The cable and casing are listed as PN 1567793 with a cable length of 68 5/8 inches. My housing measures just over 57 inches in length. Is my existing housing correct?
  • Jim L.
    • September 30, 1979
    • 1817
    Re: 54 speedometer cable/gear
    It doesn't. The gear, shaft, and holder are a non-serviceable assembly. If you can't separate the stub of the speedo cable from the speedo gear assembly, you'll need to find a replacement.
    Jim
