Problem: the new '67 front clip sets too high where it meets the cowl area at the bottom of the windshield and doors (see pictures below). Lifting up on the front end fixes the problem, but then the bottom of the radiator support mounts are each about 1-1/4" above the frame horns where they should attach.
Shims for this area are shown on UPC 11-13-A5. Posts in the archives say the number of shims under the radiator support mounts were determined at the same time as the body mount shims, and then welded in place (radiator support shims only were welded - why?).
How many shims were typically used at the radiator support location? Something is off, I can't imagine 16 to 20 shims at 1/16" thickness each being used there.
Ideas or suggestions?
