Rear End Carrier date vs Build Date - NCRS Discussion Boards
+ More Options
Posts
  • David S.
    • August 9, 2009
    • 595
    Hi Guys,
    Can someone tell me an acceptable date range for a rear end carrier in comparison to a build date....
    For instance, is a rear that was cast in Oct 66 with a mid Nov 66 assembly date work for a car that was built in mid-late Nov 66? Or should there be a larger gap (maybe a month or two) in between the assembly date of the rear and the build date of the car?
    Dave
  • Stephen L.
    • May 31, 1984
    • 3161
    Re: Rear End Carrier date vs Build Date
    My 67 has a differential date stamp of 3/31 on a body build date of 4/10.
    • Russ S.
      • April 30, 1982
      • 2163
      David, There should be no problem with those dates.
      • David S.
        • August 9, 2009
        • 595
        Thanks guys!
        • Wayne M.
          • March 1, 1980
          • 6414
          Here's another, off an empty '67 BB carrier I have; Cast D_12_7, assembled AU 5_17_67.
