AC 4656 Fuel Pump-Restamp? - NCRS Discussion Boards
  • Joe M.
    • April 30, 1990
    • 1343
    I purchased a 4656 fuel pump from Show Cars Automotive. I was expecting to see the "4656" stamped deep into the mounting flange, but the attached photos show how shallow the stamping is. Although the flange area is flat, I compared it to a 4656 that is shown in the 1958-1960 Restoration Handbook. The flange has the same characteristics; a middle seam that wraps around the corner, followed by a flat spot, then the seam continues around the flange. If it is a restamp, you would think they would have done a better job of stamping. As long as it works, it probably does not matter, unless NCRS judge believes it is a restamp.
    Restamp or not?
  • Joe M.
    • April 30, 1990
    • 1343
    Re: AC 4656 Fuel Pump-Restamp?
    The remainder of the pump appears to be accurate, small AC on top, large AC on bottom cap, slot screws. I don't know of anything other identifying features of the 4656.
    What type of metal is the pump arm to pump body pin made of on the originals? I thought I read somewhere that is was suppose to be brass.
    • David L.
      • July 31, 1980
      • 3310
      Joe,
      I have never owned an original AC 4656 fuel pump but I have owned many original and NOS AC 4657 fuel pumps. A 4657 fuel pump has a hole near the outlet end with a 2-digit casting year with anywhere from 1 to 12 radial line segments (or hash marks) to denote the month.
      Does your 4656 pump have the same?
      BTW, a 4657 pump can be converted to a 4656 pump as shown in the instructions shown below.
      Dave
        Joe -
        That pin is steel.
        • Joe M.
          • April 30, 1990
          • 1343
          No numbers except the faint 4656 stamped on the flange. Attached are a few more photos.
          • Joe M.
            • April 30, 1990
            • 1343
            My pump has the correct pin! If you notice, the pump shown in the ad is not made like the pump they sent me. I did not deal with a vendor on e-bay or Driveline and this may be the result. I would still like to see a photo of a documented original 4656. May not be time to call it a less than advertised deal yet.
            • Russ S.
              • April 30, 1982
              • 2163
              I realize this is a 4656 but I have seen original 4657s that are both ways-with the stamp deep and with them faint.
              • Joe M.
                • April 30, 1990
                • 1343
                Russ, that is the type of info I was looking for. A photo of an original 4656 would put me at ease. There is one good photo in the 1958-1960 Restoration Handbook, but need to see more pump body details. Probably a moot point since the vendor would never return my $$ anyway.
                • David L.
                  • July 31, 1980
                  • 3310
                  Joe,
                  Did you use a magnifying glass. The 2-digit number and hash marks are sometimes hard to see. Since your pump is rebuilt the bottom part might be from a different AC pump.
                  I have a rebuilt AC "6942GE" pump ("GE" = July 1965) with a "59" casting year in the hole near the outlet. In this case the rebuilt pump was made from a 1965 top section with a 1959 bottom section. This pump is in a NAPA box, NAPA part # 40004.
                  Dave
                  • Donald H.
                    • November 2, 2009
                    • 2594
                    Here are photos of mine off my 60. Of course I don't have an history so I can't say it is a period correct pump or not. The font on mine seems a bit different than yours, but not sure if that is meaningful.
                    Another thing I noticed is that yours seems to have a mold parting line around your flange except where the number is stamped, mine does not have that.
                    Don
                    Don Harris
                    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
                    • David L.
                      • July 31, 1980
                      • 3310
                      Don,
                      Assuming you have an original pump from your 1960 there should be a "59" or "60" casting with 1 to 12 "hash marks" inside the hole just above the threaded outlet hole.
                      Dave
                      • Donald H.
                        • November 2, 2009
                        • 2594
                        Originally posted by David Liukkonen (3775)
                        Don,
                        Dave
                        I haven't been able to see the year date. But I did find the hash marks. They run from about 2 o'clock to 7 o'clock. It's hard to tell, but looks like 7 or 8 marks.
                        Don
                        Don Harris
                        • David L.
                          • July 31, 1980
                          • 3310
                          Don,
                          Try using a Q-tip with some solvent to clean the hole. A magnifying glass might also help.
                          Dave
