speedo cable - why two pieces? - NCRS Discussion Boards
  • Randall K.
    • April 1, 2005
    • 184
    Does anyone know why GM used a two-piece cable? Just curious...
    I'm assuming that there would be a judging deduction if I used a one-piece replacement, as you can see the junction of the cables under the car (at least I can see mine).
    Randy
  • Michael W.
    • April 1, 1997
    • 4290
    Re: speedo cable - why two pieces?
    Later cars with cruise control required a two piece cable to accommodate the drive/sensor unit located in the engine bay.
    • Rich C.
      • January 1, 1994
      • 383
      That would make sense, however they started using two piece, long before they started installing cruise in vettes. Also where they connect seems to be much lower than any junction with cruise components. Just found a nos lower cable, took a long time!
      '73 LS-4 454 owned for 21 1/2 years!
      • Jim T.
        • March 1, 1993
        • 5351
        Rich my July built original owner 1970 350/300 turbo 400 has the two piece speedometer cable.
