Aftermarket A/C Questions - NCRS Discussion Boards
  • Mike M.
    • July 24, 2011
    • 297
    I recently bought a nice, very original '65 Coupe. I am going to have it judged in a Chapter event in Nov. Sometimes after that but before next Summer I am going to add a/c to this non-air car. I live in the Deep South and it is hot as hades down here. This car is a sure good driver and I plan to drive it. A/C is a necessity (especially if my wife is to go with me). I guess the addition of air to a non air car causes a point deduciton in any judging? I know the alternator has to be moved from the pass side to the driver's side to make room for the compressor. Old Air Inc makes a system that uses a compressor that looks very much like the old Frigedair compressor although it is the new modern (Sanden?) type. I am rambling but am interested in knowing if the addition of a/cto a non a/c kills you in a judged event. Thanks for any advice. Mike
  • Don H.
    • December 1, 1981
    • 1496
    Re: Aftermarket A/C Questions
    If you search the archives you will find this has been asked before. Basically you will have a deduct for every hole that is there but shouldn't be. Possibly a few other things, I don't think it will "kill" you in judging. Good luck, Don H.
    • Domenic T.
      • January 29, 2010
      • 2452
      Mike,
      You can also use the stock compressor and brackets under the hood if you want that area to look stock.
      All that is available.
      DOM
        Mike -
        You will get (full) deductions for all the original non-A/C parts that are missing.
