Tele Steering Column 1965 - NCRS Discussion Boards
  • Michael M.
    • November 1, 2001
    • 411
    Hi, Does the Telescopic Column on the 65 have and spring and clamp like the standard columns? AIM does not show a lower view for the telescopic column so normally I would assume it is the same as standard but wanted to make sure before I install. My telescopic column did not come with any. Thanks Mike
  • Jim S.
    • August 31, 2001
    • 730
    Re: Tele Steering Column 1965
    The 1965 - 66 telescoping column has a groove in the solid steering shaft with a round wire ring, a thin flat washer, and a spring holding the lower bearing in place. The spring has some type of felt packing on it's outside diameter.
    Jim
    • Michael M.
      • November 1, 2001
      • 411
      Thanks Jim, I am going to examine mine right now. Mike
      • Ronald C.
        • March 1, 2002
        • 77
        anyone have a good picture of a correct assemly showing the spring assmebly? i have gone back and forth at recent judging and need some help
        • Jim S.
          • August 31, 2001
          • 730
          Here is the best that I can do on the 1965-66 Corvette Telescoping Steering Column lower bearing assembly.
          The quality of the drawing is just not that great. I added several part call outs so that all the parts are identified. The spring appears to be about 1/8 inch wire and is nearly compressed to solid height.
          Saginaw manufactured the 1965-66 telescoping steering column. Chevrolet designed (and somebody manufactured or St. Louis assembled) the standard (non-adjustable) 1963-66 steering column. I am fairly sure that Saginaw probably copied the lower bearing design from the already in-production standard column for their telescoping column.
          Saginaw only manufactured adjustable (telescoping, tilt, and tilt & telescoping) steering columns until they became the 100% supplier of GM passenger car steering columns (both standard and adjustable) in 1967 with the introduction of the first generation, energy absorbing, collapsible steering columns.
          Jim
          Jim
