Need C1 Powerglide "Expert" - NCRS Discussion Boards
  • Joe M.
    • April 30, 1990
    • 1338
    I am trying to find a detailed reference document that shows exploded views of the 1960 cast iron Powerglide so I don't have to ask so many questions. Anyone have a source?
    A steady stream of drips run out of the side of the rear extension; through the speedometer connection and the car has not been started in a month. I removed the speedo cable and the steel bullet-shaped part (don't know the correct name of the part) that is male threaded on the outside and is hollow in the center for the plastic speedo gear to spin. I replaced the o-ring on the bullet, but I believe the ATF may be coming through the "annular" space between the plastic gear and the steel gear holder for lack of the correct part name.
    Is this possible and if so would it alleviate the problem to purchase a new plastic speedo gear?
  • Gary C.
    Administrator
    • October 1, 1982
    • 17657
    Re: Need C1 Powerglide "Expert"
    Joe,
    Drop Joel Adams an email. Joel's a member of the TDB and resides in North Texas.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Joe M.
      • April 30, 1990
      • 1338
      Thank you Gary, I will contact him. I also found a Powerglide repair manual on the internet last night; a pdf download for $10.
