1960 283 Camshaft - NCRS Discussion Boards
1960 283 Camshaft
  • Philip P.
    • February 28, 2011
    • 558
    1960 283 Camshaft
    Would a new camshaft have to be grooved/slotted for oiling? The engine is a 1960 283/230. It presently has a solid lifter cam and would like to change it out to something closer to correct. I am looking at a Lunati 20109 that they recommend. Also any other recommendations would be appreciated. This is part of a winter project.
    Phil
    • 43279
    Re: 1960 283 Camshaft
    Phil
    Phil------
    1960 small blocks do not require the rear journal groove.
    You can obtain an excellent replacement cam under GM #14060651.
    • Philip P.
      • February 28, 2011
      • 558
      Joe,
      Thanks for the information, that is what I thought but it came up. Will look into the GM replacement. Closer to original would be preferred.
      Phil
        • 43279
        Joe,
        Phil
        Phil-----
        I don't think you'll be able to discern the difference between the original camshaft and 14060651 in terms of idle quality and general performance. It should be virtually identical.
        Also, you might check with GM dealers like the old Sallee Chevrolet in Oregon (now a different name which I've forgotten) and Scoggins-Dickey in Texas. These dealers remove these cams from GM crate engines and build up the engines with other cams and parts to higher performance levels. The removed brand new cams are sometimes sold at very low prices.
        • Philip P.
          • February 28, 2011
          • 558
          Joe,
          $49.95 with lifters at Pace Performance removed from new engine. My debit card is on fire.
          Thanks for the information..
          Phil
          • James O.
            • November 1, 1985
            • 160
            i think i saw that jeff reade at american motoring memories in calif is offering a close replacement to the 097 cam you want. he is a legit guy.
              • 43279
              James-----
              The '097' cam was not used in a 283/230hp as is Philip's.
              • James O.
                • November 1, 1985
                • 160
                right,joe. i read the post too quickly and thought he was looking for the solid lifter cam.
                • Philip P.
                  • February 28, 2011
                  • 558
                  Thanks all, I purchased the cam at Pace Performance, it is a GM dealership used to be Pontiac. I think the cam that I have in the car is a GM solid lifter from the past. Can it be identified when removed? The cam works fine but the type of use that the car gets now I think the new cam will be more user friendly
                  Phil
                  • Joe R.
                    • May 31, 2006
                    • 1822
                    Phil
                    Phil,
                    The old cam should have some numbers on it, if it's GM. Post those numbers here.
                    Joe
                      • 43279
                      Phil
                      Phil-----
                      It definitely will. The cam you purchased which is the current iteration of the one generally known as the "300 HP cam". This cam is one of the best street cams EVER used in a Corvette. Period.
                      By the way, its name in the vernacular is derived from its use in 327 and 350 cid engines. It will not produce 300 horsepower in your application.
                      • Timothy B.
                        • April 30, 1983
                        • 5202
                        Phil,
                        When you remove the old solid lifter camshaft be very careful to keep the lifters in the exact order as they came out of the block.
                        Don't get in a hurry because someone may be able to use the old camshaft and lifters if all is in good condition but it's very important to put the lifters back to the same lobe they were running with.
                        • Philip P.
                          • February 28, 2011
                          • 558
                          I have heard good things about the old 327/300hp cam, that should be a good match for my engine.
                          Thanks for the tip on the lifters I will be sure to keep them in the correct order not sure if it is worth anything but will see when it is replaced this winter.
                          Thanks again for all the help and information.
                          Phil
