Exhaust Stud Help Needed - NCRS Discussion Boards
  • Justin B.
    • March 1, 1996
    • 478
    I just recently found out that I didn't have the correct nuts on my exhaust manifolds. I replaced five without a problem The sixth stripped the threads on the stud. The engine hasn't ever been run but the entire exhaust system has been "locked down" in place. I finally got the nut off by cutting it with a fine burr and a dremmel tool. Is there anyway possible to get the stud out with removing the manifold? By the way, the studs have been replaced so they are new also.
  • Bob R.
    • June 30, 2002
    • 1595
    Re: Exhaust Stud Help Needed
    I assume you want to remove the stud to repair the threads? You can purchase a thread chaser that is close in size to a nut. You can then run it up and down the stud with a deep neck socket.
    • Michael G.
      • November 12, 2008
      • 2158
      If you have un-stripped threads left near the dog point of the stud, run two new (free-spinning, non-locking) nuts on as far as you can without reaching the stripped threads.
      Using two wrenches, tighten the two nuts against one another. Remove the wrench from the nut closest to the end of the stud and try to loosen the other nut (the one closest to the stripped threads) while not holding the nut closest to the dog point end. The stud should loosen.
      Mike
      1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
      1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
      • Justin B.
        • March 1, 1996
        • 478
        The stud's threads are stripped almost at the very bottom. I can't get a nut started and no, I don't plan on repairing the stud. It's ruined.
        • Domenic T.
          • January 29, 2010
          • 2452
          Sounds like vise grips next.
          DOM
          • Anthony P.
            • June 27, 2010
            • 485
            vice grips and some heat on the manifold will help. Since the engine has not been run, you may be able to get away with just a little heat and use a propane torch, versus a hotter one.
            • Paul Y.
              • September 30, 1982
              • 570
              If you can get to the top of the stud after you have it heated up well melt some wax on it and let it run down from the top where it comes through the manifold. It should come out easier.
              It's a good life!
              • Clem Z.
                • January 1, 2006
                • 9427
                you can buy reverse twist drill bits for using in a reversible electricral drill. if you start drilling the stud and it is not frozen most likely the drill bit will spin the stud out. it has worked for me
                • Steven B.
                  • June 30, 1982
                  • 4011
                  That is how I did it. Since I was doing it to junk yard parts I soaked with WD-40 before I used the drill. If you use a battery powered drill make certain it has enough power. I used my corded drill.
                  • Gary J.
                    • April 1, 1980
                    • 1246
                    In otherwords they are called left hand drill bits
                    • Steven B.
                      • June 30, 1982
                      • 4011
                      Gary, since I am left handed I just call them normal drill bits. Now the right handed ones---
                        • 43273
                        Justin------
                        If these are new studs that were installed in relatively clean manifold threads, you should be able to turn them out easily using vice grips.
                        By the way, these studs should always be installed using high temperature anti-seize compound.
                        • Joe R.
                          • May 31, 2006
                          • 1822
                          Justin,
                          Here's some more ideas for you:
                          https://www.forums.ncrs.org/showthre...66880&uid=2403
                          Joe
                          • Michael G.
                            • November 12, 2008
                            • 2158
                            As I recently installed some repop nuts on the studs on my 63 I noticed that the nuts had a very significant amount of prevailing torque (the torque it takes to overcome the thread interference in a Lock nut). The torque was much higher than I would expect in a normal GM lock nut. The torque was so high that the threads of the exhaust stud were deformed during installation.
                            I remedied this by adding wax to the nut before driving it. Original nuts always had a wax coating over the zinc or cad plating. The wax was adjusted by the original nut manufacturer to set the friction to achieve a predetermined run-down torque. I doubt that my repops had this wax as purchased.
                            Please be advised that if such nuts damage your studs in any way, the friction or thread interference is too great - there should be no appreciable thread galling (damage) caused by the nut. To avoid this, Melt some wax into the nut threads to decrease friction. Note that the deformation of the original nuts was also very closey controled. If the repop nut is deformed too much during manufacture, you may not be able to prevent stud damage by adding wax, so take a good look at the stud threads after you install the first one.
                            Mike
                            • Paul J.
                              • September 9, 2008
                              • 2091
                              Justin, good suggestions here, but I think that you need to either remove the manifold or at least loosen it enough to pull it away form the block 1/2" to 1". I would then soak it with Kroil for a day or so, then hit it on the end (as if driving it into the block), and then soak it with Kroil for another day or so. I would then first go to the vice grips, and if that did'nt work, I would go to the heat with the vice grips.
                              Whatever you do, both Kroil, the heat, or anything else will be most effective if you can put it directly on connection between the stud and the block.
                              Good luck,
                              Paul
