What d'ya call those figure 8 shaped bolt heads? - NCRS Discussion Boards
  • Norris W.
    • December 1, 1982
    • 685
    The one I'm talkin' about is what holds the metering block on a side inlet Holley or in this case the inner door handle bolts on some straight axle Corvettes. I stopped a tool truck this week and asked the guy and he didn't know what I was talkin' about, so I drew him a picture. He said his granddad called 'em buggerheads, but he didn't have any idea where to find a tip that'd fit 'em. Buggerhead search on the internet didn't help.
  • Tom H.
    • December 1, 1993
    • 3440
    Re: What d'ya call those figure 8 shaped bolt heads?
    Clutch head
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Robert S.
      • May 31, 1988
      • 81
      Sounds like you're talking about clutch head bolts and screws. Clutch head screwdrivers are available at Sears.
      • Norris W.
        • December 1, 1982
        • 685
        Thanks guys.
        • Gary B.
          • September 30, 1987
          • 305
          You can also make your own using bolts and grinding down the sides. The bolt will fit a socket set.
          • Gary C.
            Administrator
            • October 1, 1982
            • 17969
            Snap On sells socket clutch head drivers
            Gary
            NCRS Texas Chapter
            https://www.ncrstexas.org/
              • 43289
              Originally posted by Norris Wallace (6139)
              Thanks guys.
              Norris-----
              Some of the clutch head screws, especially some of those used on Holley carbs, use an uncommon-size clutch head driver. I don't know if Sears has those. Snap-On might.
              • Larry M.
                • January 1, 1992
                • 2703
                Norris-----
                TRU-VALUE Hardware stores sell 2 or 3 different size clutch-head screwdrivers. Very good quality screwdrivers and relatively low price (compared to Snap-On)
                They fit the Holley carbs........that's why I purchased them.
                Larry
                • Chuck S.
                  • June 30, 1991
                  • 184
                  Is there such a thing as a "male" clutch head??? Trico vacuum windshield wiper motors of the mid-fifties used special screws which I`ve heard were called male" clutch heads. I`ve been unable to find a source for these special Trico screws.
                  • Gary C.
                    Administrator
                    • October 1, 1982
                    • 17969
                    Chuck,
                    There's a clutch head winged type "security screw" that has raised edges. Used on locks, etc. that are not supposed to be easily removed.
                    Gary
                    NCRS Texas Chapter
